I use odrive to keep in sync all my cloud accounts, but it seems I can’t get desktop sync to work properly from my work pc. If I save something in my odrive folder, it remains stuck forever in the “Waiting” status (pink badge or no badge at all); i can correctly uppload a file via web to odrive – and that works, but only if it is a new file: in it is a new version of an existing file, syncing fails (IMO correctly, to avoid duplicate versions).
My work pc is behind a proxy: is that relevant?
BTW, syncing in the opposite direction works seamlessly.
Hi @a.m.buongiovanni,
Unfortunately we do not fully support proxy on the desktop client yet, so that could be the reason you are seeing this behavior behind your company proxy.
Can you try sending a diagnostic from the odrive tray menu?
