OwnCloud integration
#1
Can we have a owncloud integration ?
I has a recorrent nightmares (* just kidding ) with something bad occurs to my nas (like a power surge due to strike) and i lost all my files. But is really hard to sync them with every cloud.
Odrive is a very good tool, and i will like to sync my owncloud personal cloud storage throught odrive to my dropbox, google drive and others supported.
OwnCloud Support/Integration
#2
Hi @samuelgerevini,
odrive can link to OwnCloud using the WebDAV integration (https://www.odrive.com/links/webdav). There is documentation here for OwnCloud: https://doc.owncloud.org/server/latest/user_manual/files/access_webdav.html
Please note, though, that odrive cannot sync one link to another, so your original plan of trying to sync your owncloud to Dropbox or Google Drive wouldn’t work, at least directly. If you are hosting your own OwnCloud, though, and have access to the underlying data, it would be possible to sync that data to cloud storage.
#3
Hello,
If it’s okay, I would like to request support or integration for OwnCloud please.
#4
Hi @nightzz789,
Please take a look at the above post.
