So as I am unable to sync the folder I’d like directly from file explorer: http://puu.sh/qmX8p/b6d63742a2.png I have mapped it as a ‘network location’.
You cannot sync to a folder via a UNC path. The network drive will need to be mounted as a drive letter. You will also need to make sure that odrive has write-access to that folder. Can you try that and see if you have better luck?
Ah ok, so I had it mapped as a network space as opposed to a network drive, always get all that confused. It seems to be working now, thanks for your assistance Tony!
