Is the odrive client's communication direct to the storage?
I would like to know how the odrive sync mechanism works. If I use a Google Drive account (or other/others), are the files sent from the local client directly to the corresponding remote storage, or do they go through odrive servers first?
Best regards,
The odrive desktop client communicates directly with the linked storage. If you add or modify a file in odrive/Google Drive, for example, the odrive desktop client will upload the new data directly to Google, without passing through any intermediaries.
