Odrive is not syncing all gdrive files & folders shared with me.
I am the owner of the main folder in gdrive,
I then shared with someone at work,
They have then created new files and folders (in my folder, thus also shared with me (she also shared manually with me to be sure in (web) gdrive))
Odrive refuses to see or sync these files locally:
https://gyazo.com/35d6da20569f2769fc8b928d78e3e45f -
However odrive can clearly see the files itself in web version:
https://gyazo.com/db80a73cb204d9bdbb88b5d5f7021863 -
During testing, I created a “Test” folder, this was picked up instantly without prompting by odrive.
Also pulled in 5 other folders from the folder above this one, to test whether they would sync, they did.
Appears to be something with permissions, like a bug with odrive syncing folders that have been shared with me, but I’m not the owner of.
Although ^ seems best explanation, either contradicted by, or does not apply to files (one word doc in there I was not the owner of was synced fine)
Repeated refreshes and syncs do nothing.
Thought might be as beginning of this folder now begins with “__” however other similarly named folders are fine, and test docs & files I make are fine and sync without prompting.
Files are just simple word docs, & so very small.
^ Attached Screenshots & Preemptively sending diagnostics report on the chance you would like to see it.
Any thoughts?
