Odrive does not start
Hello! My “odrive app” does not start automatically with windows nor by the application shortcut, even by clicking on the executable file. And no error message is displayed. I’m using windows 10.
Hi @jonatascunha,
Did you recently update Windows, or did odrive suddenly stop working without any changes to the system?
Can you try running odrive using this command from a command prompt? You can open up a command prompt by clicking on the Windows icon in the taskbar, typing “cmd”, and then clicking on “Command Prompt”.
Once the command prompt is open, copy and paste the following command in (all one line) and hit enter. This will run the main odrive application and hopefully spit out some useful information. Please wait until the process closes and then copy and paste the output or take a screenshot of the command prompt window and post it here:
powershell -command "&{$bin=$(ls \"$HOME\.odrive\bin\" | sort Name -desc | select -f 1).FullName; Start-Process \"$($bin)\odriveapp.exe\";}"
Windows has been updated today and, apparently, the odrive app returned to normal startup.
Tks
Glad to hear it! Thanks for the update.
