On one of my machines, every time I right-click a folder and choose “Sync” (with options “Download: Nothing” and “Include subfolders”) odrive immediately exits.
Version 6002
Version 6002
Hi @Zero_G,
Let’s try running from the terminal to see if anything spits out before it closes.
Can you also check for any recent crash reports. You can find the reports by going to Finder -> Go -> Go to folder and then pasting this in:
~/Library/Logs/DiagnosticReports/
We are looking for any recent reports starting with “odrive”.
Thanks. I’m taking a look and will respond in the PM
