After synching folder on my mac i don’t have flag/check column in the folder.
Hi @federico.roveda,
Do you see checks on other files and folders, or are they missing on everything? Do you have the right-click options?
Hi, they are missing everywhere… but file and folder are correctly synched.
Yes, right click is enabled
Was this working properly before and then suddenly stopped?
Please exit odrive then install the latest version from here: https://www.odrive.com/downloaddesktop?platform=mac
Once installed, if the behavior is the same, please check the OS X System Preferences -> Extensions tab and make sure odrive is listed as a Finder extension and it is enabled. If it is, please try toggling it off and on to see if the behavior changes.
Hi Tony, now it works again!!
Tk
Federico
Great! Thanks for the update.
