I’ve just installed latest version on El Capitan and I don’t see Odrive actions (i.e. unsync) when I do right click on on the the file or folder.
Any ideas?
Any ideas?
Seems that restarting the computer fixed it.
Glad you got it sorted. I’ve seen, on occasion, where Finder fails to load the extensions properly. I’ve actually seen this with other extensions too. Another way to remedy is to try toggling the extensions in System Preferences.
