A folder on my OneDrive is not showing any longer in my odrive. I tis there on OneDrive. How do I get i back in odrive?
Hi Bruce,
Do you see the OneDrive folder listed on the web client here? https://www.odrive.com/account/myodrive
If so, can you take a screenshot of that view and one of the desktop view and post here. Can you also send over a diagnostic from the odrive tray menu?
Yes, I see it.
Also, how do I get into my deleted folder in odrive?
I sent a report.
Hi Bruce,
Can you try send another diagnostic please. The last one didn’t make it through.
For odrive trash, you can see the status in the odrive tray menu:
Do you see anything listed in the trash currently?
I found the folder in the trash and put it back so everything is fine.
