Keep folder local (permanent)
i have 1 directory in a cloud drive that i always want to keep a local copy of. is there a way to do this using odrive?
thanks
Hi @dayguess,
You can sync down any files or folders locally and they will stay local until you unsync them.
There is also a Premium feature that allows you to set rules on a folder, so that it will always download any new content in a folder, bypassing the placeholder state. More on that here: https://docs.odrive.com/v1.0/docs/sync-source-changes#section-configure-folder-sync-rules
Thanks, will they stay in sync if I make them local?
Hi @dayguess,
Yes, once a file has been synced locally, it will stay in sync if it is changed remotely.
