There are two days I’m trying to open the odrive, but it does not open. I click on the icon and it just does not open, being 3 days ago was working perfect.
Hi @rafaelcilios,
Try these steps and see if it helps:
Run the following command in the terminal session (copy & paste + Enter):
This will reset the bin folder and re-run odrive. Hopefully this will clear out the issue.
This worked for me on Mac, thank you!
