I have the odrive agent installed and authorised - How do I perform the initial sync as I do not yet have any place holders ?
Hi @chris12,
Can you tell me where you are in the setup steps here? https://docs.odrive.com/docs/odrive-sync-agent#section--using-odrive-sync-agent-
It sounds like you’ve gone up to step 3, so far. Did you create the agent mount from step 4?
