Hi everyone,
I just wanted to join the party. But my installation failed. Here is the log, just in case:
[14D0:0540][2016-11-04T05:14:03]i001: Burn v3.10.3.3007, Windows v6.1 (Build 7601: Service Pack 1), path: C:\Users\TOSHIBA\AppData\Local\Temp{B73B7D81-5311-4CE1-B606-3848906B836A}.cr\odrivesync.5997.exe
[14D0:0540][2016-11-04T05:14:03]i009: Command Line: ‘-burn.clean.room=C:\Users\TOSHIBA\Desktop\odrivesync.5997.exe -burn.filehandle.attached=532 -burn.filehandle.self=540’
[14D0:0540][2016-11-04T05:14:03]i000: Setting string variable ‘WixBundleOriginalSource’ to value ‘C:\Users\TOSHIBA\Desktop\odrivesync.5997.exe’
[14D0:0540][2016-11-04T05:14:03]i000: Setting string variable ‘WixBundleOriginalSourceFolder’ to value ‘C:\Users\TOSHIBA\Desktop’
[14D0:0540][2016-11-04T05:14:03]i000: Setting string variable ‘WixBundleLog’ to value ‘C:\Users\TOSHIBA\AppData\Local\Temp\odrive_20161104051403.log’
[14D0:0540][2016-11-04T05:14:03]i000: Setting string variable ‘WixBundleName’ to value ‘odrive’
[14D0:0540][2016-11-04T05:14:03]i000: Setting string variable ‘WixBundleManufacturer’ to value ‘Oxygen Cloud, Inc.’
[14D0:1490][2016-11-04T05:14:03]i000: Setting numeric variable ‘WixStdBALanguageId’ to value 1033
[14D0:1490][2016-11-04T05:14:03]i000: Setting version variable ‘WixBundleFileVersion’ to value ‘1.0.5997.0’
[14D0:0540][2016-11-04T05:14:03]i100: Detect begin, 3 packages
[14D0:0540][2016-11-04T05:14:03]i000: Setting string variable ‘Net46Installed’ to value ‘378758’
[14D0:0540][2016-11-04T05:14:03]i052: Condition ‘Net46Installed >= 393295’ evaluates to false.
[14D0:0540][2016-11-04T05:14:03]i101: Detected package: Net46, state: Absent, cached: None
[14D0:0540][2016-11-04T05:14:03]i101: Detected package: Odrive_x86.exe, state: Absent, cached: None
[14D0:0540][2016-11-04T05:14:03]i101: Detected package: Odrive_x64.exe, state: Absent, cached: Complete
[14D0:0540][2016-11-04T05:14:03]i052: Condition ‘VersionNT >= v6.1’ evaluates to true.
[14D0:0540][2016-11-04T05:14:03]i199: Detect complete, result: 0x0
[14D0:1490][2016-11-04T05:14:10]i000: Setting numeric variable ‘EulaAcceptCheckbox’ to value 1
[14D0:0540][2016-11-04T05:14:10]i200: Plan begin, 3 packages, action: Install
[14D0:0540][2016-11-04T05:14:10]i052: Condition ‘(VersionNT >= v6.0 OR VersionNT64 >= v6.0) AND (NOT Net46Installed >= 393294)’ evaluates to true.
[14D0:0540][2016-11-04T05:14:10]w321: Skipping dependency registration on package with no dependency providers: Net46
[14D0:0540][2016-11-04T05:14:10]i000: Setting string variable ‘WixBundleLog_Net46’ to value ‘C:\Users\TOSHIBA\AppData\Local\Temp\odrive_20161104051403_000_Net46.log’
[14D0:0540][2016-11-04T05:14:10]i052: Condition ‘NOT VersionNT64’ evaluates to false.
[14D0:0540][2016-11-04T05:14:10]i052: Condition ‘VersionNT64’ evaluates to true.
[14D0:0540][2016-11-04T05:14:10]i000: Setting string variable ‘WixBundleRollbackLog_Odrive_x64.exe’ to value ‘C:\Users\TOSHIBA\AppData\Local\Temp\odrive_20161104051403_001_Odrive_x64.exe_rollback.log’
[14D0:0540][2016-11-04T05:14:10]i000: Setting string variable ‘WixBundleLog_Odrive_x64.exe’ to value ‘C:\Users\TOSHIBA\AppData\Local\Temp\odrive_20161104051403_001_Odrive_x64.exe.log’
[14D0:0540][2016-11-04T05:14:10]i201: Planned package: Net46, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: Yes, dependency: None
[14D0:0540][2016-11-04T05:14:10]i201: Planned package: Odrive_x86.exe, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[14D0:0540][2016-11-04T05:14:10]i201: Planned package: Odrive_x64.exe, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[14D0:0540][2016-11-04T05:14:10]i299: Plan complete, result: 0x0
[14D0:0540][2016-11-04T05:14:10]i300: Apply begin
[14D0:0540][2016-11-04T05:14:10]i010: Launching elevated engine process.
[14D0:0540][2016-11-04T05:14:15]i011: Launched elevated engine process.
[14D0:0540][2016-11-04T05:14:16]i012: Connected to elevated engine.
[1A44:1BE0][2016-11-04T05:14:16]i358: Pausing automatic updates.
[1A44:1BE0][2016-11-04T05:14:16]i359: Paused automatic updates.
[1A44:1BE0][2016-11-04T05:14:16]i360: Creating a system restore point.
[1A44:1BE0][2016-11-04T05:14:28]i361: Created a system restore point.
[1A44:1BE0][2016-11-04T05:14:28]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{47e021cf-aac1-492f-a584-62436b9dc0d0}, options: 0x7, disable resume: No
[1A44:1BE0][2016-11-04T05:14:28]i000: Caching bundle from: ‘C:\Users\TOSHIBA\AppData\Local\Temp{5A91DFE9-CDCF-4E53-BD56-FB60A91BC36E}.be\odrive.exe’ to: ‘C:\ProgramData\Package Cache{47e021cf-aac1-492f-a584-62436b9dc0d0}\odrive.exe’
[1A44:1BE0][2016-11-04T05:14:28]i320: Registering bundle dependency provider: {47e021cf-aac1-492f-a584-62436b9dc0d0}, version: 1.0.5997.0
[1A44:1BE0][2016-11-04T05:14:28]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{47e021cf-aac1-492f-a584-62436b9dc0d0}, resume: Active, restart initiated: No, disable resume: No
[1A44:0074][2016-11-04T05:14:29]i305: Verified acquired payload: Net46 at path: C:\ProgramData\Package Cache.unverified\Net46, moving to: C:\ProgramData\Package Cache\480CA134B9E3F2437DF10719D5A8C77DDEC0A4F1\Microsoft .NET Framework 4.6 Setup.
[1A44:0074][2016-11-04T05:14:29]i304: Verified existing payload: Odrive_x64.exe at path: C:\ProgramData\Package Cache{875FA7FB-21D0-46D0-A60B-057E18CBAA16}v1.00.5997\odrive.x64.msi.
[1A44:0074][2016-11-04T05:14:30]i304: Verified existing payload: cabF86E6C821B5C13030D55C93C8C703EA3 at path: C:\ProgramData\Package Cache{875FA7FB-21D0-46D0-A60B-057E18CBAA16}v1.00.5997\odrive.cab.
[1A44:1BE0][2016-11-04T05:14:30]i301: Applying execute package: Net46, action: Install, path: C:\ProgramData\Package Cache\480CA134B9E3F2437DF10719D5A8C77DDEC0A4F1\Microsoft .NET Framework 4.6 Setup, arguments: ‘“C:\ProgramData\Package Cache\480CA134B9E3F2437DF10719D5A8C77DDEC0A4F1\Microsoft .NET Framework 4.6 Setup” /passive /norestart /SkipMSUInstall /ChainingPackage “odrive” /showfinalerror’
[1A44:1BE0][2016-11-04T05:14:38]e000: Error 0x800713ec: Process returned error: 0x13ec
[1A44:1BE0][2016-11-04T05:14:38]e000: Error 0x800713ec: Failed to execute EXE package.
[14D0:0540][2016-11-04T05:14:38]e000: Error 0x800713ec: Failed to configure per-machine EXE package.
[14D0:0540][2016-11-04T05:14:38]i319: Applied execute package: Net46, result: 0x800713ec, restart: None
[14D0:0540][2016-11-04T05:14:38]e000: Error 0x800713ec: Failed to execute EXE package.
[1A44:1BE0][2016-11-04T05:14:38]i351: Removing cached package: Net46, from path: C:\ProgramData\Package Cache\480CA134B9E3F2437DF10719D5A8C77DDEC0A4F1
[1A44:1BE0][2016-11-04T05:14:38]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{47e021cf-aac1-492f-a584-62436b9dc0d0}, resume: None, restart: None, disable resume: No
[1A44:1BE0][2016-11-04T05:14:38]i330: Removed bundle dependency provider: {47e021cf-aac1-492f-a584-62436b9dc0d0}
[1A44:1BE0][2016-11-04T05:14:38]i352: Removing cached bundle: {47e021cf-aac1-492f-a584-62436b9dc0d0}, from path: C:\ProgramData\Package Cache{47e021cf-aac1-492f-a584-62436b9dc0d0}
[1A44:1BE0][2016-11-04T05:14:38]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{47e021cf-aac1-492f-a584-62436b9dc0d0}, resume: None, restart initiated: No, disable resume: No
[14D0:0540][2016-11-04T05:14:38]i399: Apply complete, result: 0x800713ec, restart: None, ba requested restart: No
Cheers,
Alexander
