I have windows 7 install with the latest version of odrive. upgraded today. The services never seems to launch, not showing in Task Manager. There are some folders and file that I can get to in dropbox and others do not sync. When I right click on the folder or file, and look at the properties, it shows as a CLOUDF File (.cloudf) and to be opened with odrive. Nothing happens if I double click on these folders or files.
When I log into a second windows 7 system, I can’t even see the files as part of the odirve services.
I feel my files have been hi-jacked and need to move them
Hi @gbuchan,
I’m not sure what you mean about your files being hijacked, but we can certainly look at why odrive is not functioning properly on your system. Probably the best thing to do is trying running from a command prompt, which could spit out some useful information we can use to narrow down the cause. To do that, can you please do the following:
1.Open a command prompt (cmd)
2.Copy and paste the following and hit enter:
cd “%userprofile%\.odrive\bin” && dir
3.The above command will list at least one four digit directory (like 5453). You will then want to use that number in the following command:
.\5453\odriveapp.exe
make sure you use whatever number you have, if it is not 5453
This will launch odrive. Please provide a screenshot of what you see in the command window after that.
