Can you verify this with the latest version of the odrive desktop client? It is not reproducible for me anymore, but I want to make sure you see the same thing.
Hi, this is still happening … I am sure this time, as I just moved a few files from one folder to another in Dropbox, and all the files now appear in my Trash and the “moved” files are being sync’ed as new files
Hi @Hany,
What you are seeing can sometimes happen if odrive can’t “optimize” the move operation. It has to do with how odrive picks up the changes.
Since odrive can only look at the filesystem changes, it has to try to figure out when files have been moved vs added and deleted. This move optimization can sometimes be missed, and odrive picks up the move as a delete of the files in the old location and an add of the files in the new location.
This is something we are working on tightening up in the next generation odrive product. If you have a lot of moves to make, it may be better to perform them from the Google Drive web client, as the move can be explicit there, instead of interpreted as it is on the file system.
