Trying out odrive, and after playing around with different configurations, tried to do a clean reinstall as seeing duplicate icons in tray, getting error messages like “Unable to sync OneDrive.cloudf. This file is not inside an odrive folder.”, and not seeing context menu icons.
Tried to do reinstall with deleting odrive and .odrive folders, but it seems there are lingering odrive remnants that are interfering with a clean reinstall.
Win 10 Pro ver 1709
Suggestions? Thanks
Hi @jeff4,
You performed a normal Windows uninstall, as well? This should get everything. You can also try a Deauthorizing (in the odrive menu under “Authorized User”) and then loging back in.
