While travelling, I’ve found that moving between timezones will cause odrive to identify all currently synced files as changed, thus triggering a massive re-sync.
This is especially bad, since I often rely on metered, expensive, or slow connections while travelling.
Is there any way to avoid this, other than forcing my PC to stay on my home timezone?
(This occurs on windows 10, while setting a new system timezone - either manually, or via the windows “auto timezone” feature)
Sorry to hear of the trouble, would you like to provide the requested details below?
Storage you are using to syncing your files and observing the re-sync of existing synced files.
Is this behavior consistent through out; all of your linked storage clouds?
Time zones you changed from / to?
I tried to replicate the problem in Windows 10 Enterprise x64 against my Amazon Cloud Drive and Google Drive by making changes to time zone but couldn’t observed the mentioned issue so just wanted to confirm what I am missing during the process.
This has happened several times, moving between GMT+2, GMT+3 and GMT-8.
I’ve just returned to Dutch time (GMT+1) from Jerusalem time (GMT+2). I left my laptop on Jerusalem time for fear of triggering a re-sync, but after reading your comment, changed back to Dutch time.
Indeed, for about 12 hours everything seemed fine, but this morning - after waking up my laptop and connecting to the office network, a complete re-sync was triggered. Quitting odrive, returning to Jerusalem time and re-starting odrive stopped the re-sync, but my laptop is now still on foreign time…
Sorry for the delay, I left my laptop running for whole of night and changed the time zone today multiple times but unfortunately I couldn’t replicate the issue so I would request you to re-generate same resyncing condition in your machine and then send diagnostic report from odrive tray menu.
Please let me know the following details:
Timestamp of diagnostic report
OS username
File name and folder path re-syncing in your odrive folder.
Hi Asif,
We’ve recentley switch to daylight savings time, and this seems to have triggered another resysnc, I’ve sent a diagnostic report with the following details:
Hi @odrive4,
I’m taking a look at this. Taking one file as an example “prk_450nm_gt.eps” I can see that the OS time is reporting a difference of one hour on the modification time. Generally this time should be in UTC and immune to OS timezone changes. When we query the information on the file, that time should not be changing.
Similarly to Asif, I am unable to reproduce this. Just to be sure can you give me some additional information on the system?
OS is Windows 10
The D: drive is an internal drive? What type?
What filesystem is on drive D? (right-click->properties on the drive and take a screenshot of the window, please)
This means that Windows will report a different time for the files when you change the timezone, unfortunately. The best way to combat this would be to use NTFS, so that timestamps are stored properly, in UTC.
Thanks Tony!
This also explains my previous experiance with an internal drive - it was a 2nd HD in my previous laptop and was formatted to FAT32 as well.
I’ll reformat the drive to NTFS and hope for the best
