I’m using odrive with dropbox and a folder that had been moved to the trash and then recovered in the desktop interface is no longer reflecting changes made in the web client.
If I add a file or folder through the desktop client it will be reflected in the web client, but changes made in odrive on another computer or directly in the web client don’t appear.
I’ve refreshed the folder, synced and unsynced, uninstalled and reinstalled odrive, but nothing has had any effect.
Can you show me a screenshot of the dropbox web client and the odrive web client, side-by-side to visualize the difference you are seeing? A discrepancy like this is definitely not expected.
The movies and wildwood folders are both present in the web client, but the web client has a large number of folders that the desktop client doesn’t pick up.
If you add a file to that folder on your desktop, does it show up in the web client views? If you add a file on the odrive web client, does it show up on the odrive desktop?
After performing these tests, can you send a diagnostic from the odrive tray menu?
I was able to create a file on the desktop and have it appear in the web client, and I was able to create a file on the web client and see it appear on the desktop in the odrive folder.
So now it appears to be working in both directions, which is great, but I am still missing dozens of folders on the desktop that appear in the web client.
Let me know if there are any steps you can recommend.
I took a look and it appears that all of the missing items have a carriage return (\r) at the end of the name for some reason. This will prevent it from being displayed properly on the desktop.
I have seen this before with names that were created via a script that had previously been saved in DOS format (as opposed to UNIX) and then parsed. Were these items programmatically created?
In any case, if you rename the items you should see them show up.
