Hi
i used odrive to sync slightly larger files to Amazon Clouddrive. (30GB per File) These files are encrypted and splitted (100MB) using odrive. After syncing them i unsynced them to free up space on my local hard drive. Now i tried to resync them. It seems odrive is trying to download the files and builds a hidden tempfile which increases to 5-6 GB. Probably more but i did not saw. Then the file is 0 KB and it starts increasing again. Iam using Windows 10 and odrive prod 6014?
The same problem appears with unencrypted large files.
Jens
Hi @dommaschk-jens,
Can you send a diagnostic from the odrive tray menu and I’ll take a look?
HI Tony,
i ve sent you the diagnostics pack.
Jens
Thanks.
It looks like there may be a bug here when certain cloud exception are hit. The files are fine, but the client is having trouble grabbing all of the segments.
We are looking into it now.
Thanks please give me a sign once a fix is available.
Hi Tony i tried the latest release. Now i getting the Message Amazon cloud drive internal error. This shouldnt be a Problem, because i splittet the files via odrive.
Jens
Hi @dommaschk-jens,
My apologies. This is still outstanding. The issue is rather deep, so I am investigating a work-around to be used in the meantime.
