Cannot browse PBS Cove. Please check your network connection or manage your proxy settings
My guess would be that I don’t have view access to the initial bucket just the subfolder.
pbs-ingest/mptv
I have full access to mptv but no access to pbs-ingest.
Works fine on my mac with Transmit and Cyberduck.
Hi @mptv-engineering,
Our current implementation expects the user to be able to list items from the root of the bucket, so I believe you are correct in saying the issue is you have no access the parent paths above mptv. We would probably need to account for this by adding a default path option to the S3 linking parameters, so you would start off in that folder as the root of your link. I will talk to the product team about this.
