Amazon Drive - Keeps uploading the same file again and again
Mac Version - 6344 with Amazon Drive.
The client keeps uploading the same file again and again (reaches 100% and then restarts).
The file size is 4GB.
About 2 mins ago I’ve sent the diagnostics from the odrive client.
I’ve tried removing the file and then re-uploading it - did not work.
Hi @budowski,
I have seen this sometimes with Amazon when they timeout after uploading a large file. odrive then looks at the folder, sees the file is not there (because it hasn’t finished processing yet on Amazon’s side), and then tries to upload again, in a vicious cycle.
Can you send a diagnostic from the odrive menu?
If you look at the folder from Amazon Drive’s web client, do you see the file there?
It didn’t create the file at all - but when I moved the file out of the folder, renamed it and then moved it back, it did work!
Interesting. I wonder what the underlying issue there was then. It sounds like amazon was rejecting the upload, but it is not clear why. In any case, I’m glad you got it sorted. Thanks for the update @budowski!
