The fact that the OS will sort the odrive folder alphabetically, coupled with the inability to rename the “Encryptor” and “Spaces” folders, means that it’s difficult to keep a neat, consistent naming scheme for the provider folders.
Currently, I started using things like Purpose - ProviderName (account@emailor.username)
but it was getting unwieldy. I am now using various ascii symbols for the purpose, and a descriptive name instead of the provider and email. However, it would be so much nicer if I could have either:
- The option to say “providers in a subfolder of odrive root” [yes/no] which would put all the folders/cloudf links under say odrive\Providers\xx, separating them from the Encryptor and Spaces folders
- Ability to create subfolders within the odrive folder to our own liking, with some mapping that the client does to determine which folders are which (possibly with
.odrive
files?) - Some way to rename Spaces and Encryptor, or provide a prefix for them, such that they sort separately
- Even an option of adding a “Provider Name” prefix to the folders: odrive\Dropbox\xx
I am open to other options, if anyone has come across a similar frustration and determined a good naming/sorting scheme to work around this limitation.
